I have a lot of power steering fluid under the RV due to leak in air to air charger. What can happen use that is safe to clean off underneath and some of the engine? Thank you in advance.
Any of the engine degreasers should work well altho it might not be easy to spray underneath the coach without getting it all over yourself. Wear goggles and cover yourself. Also you may want to be careful where you do it so that the petroleum residue does not kill the grass or get in to the storm drain system.
