car54DonExplorerAug 28, 2023Clearance lightsLooking for some guidance on replacing front clearance light. One is out. 2017 Winnebago. Also, where to buy? Thx in advance. Pic available.
enblethenNomadAug 29, 2023Look closely on the lens. There should be an SAE or manufacturer number. If incandescent lamp is problem, replace with LED lamps.The sockets have a good chance of rusting. Use wire brush to clean. Then use Bulb Grease to coat lamp and socket.
Related ContentTowing lights issueroof clearance lightsReplacement Lights for TTClearance LightsClearance/Tail Lights Not Working
