Gjac's avatar
Gjac
Explorer III
9 years ago
Cloudy antifreeze in radiator
I flushed the radiator several weeks with prestone chemical flush, drained per directions and filled with fresh water again then drained. I then removed thermostat reinstalled housing , removed lower hose on radiator the inserted garden hose and let that run for 15mins or so to further flush the system. I do this every couple of years. Yesterday I removed some fluid to test it and noticed it was cloudy. Could this be oil? Or chemical flush reside? I don't think I had the heater on when I flushed with hose. I did when I ran the prestone through it. Is there any way to check the oil cooler for leakage?
