j-d
Jul 22, 2014Explorer II
And the design Tito mentions is terrible. Took Ford from 1992 to 2008 to get rid of it and go back to end links on the front sway bar. But old or new, Ford's OEM sway bars, front or rear, are inadequate for a Class C.
There aren't that many bushings. Axle to Engine Crossmember, Radius Arm to Chassis, Sway Bar to Axle, Sway Bar to Front Crossmember.
Have you jacked it up at the outer ends of the axles and shaken/pried for worn Ball Joints?
38,736 PostsLatest Activity: Jul 18, 2025
