BrianinMichigan
Jul 21, 2013Explorer
Clutch fan operation
I have an issue with the clutch fan kicking in. I was under the impression that once the temps started to get around 195-200 degrees the clutch fan would kick in. With mine, it starts to kick in at just slightly over 180 degrees and once it gets slightly under 180 it will kick out. The radiator was rebuilt about 4-5 years ago and the fan clutch is new. ( The old one worked the same way ) Before the radiator was recored the fan clutch would kick in at around 195 degrees. It seems this all happens when the outside temps get above 80 degrees. I have 180 degree stat in it now and I'm thinking about going down to a 170 degree stat but don't know if it will do any good. The front of the MH is sealed up so any air coming through the grill goes through the radiator and the air dam is in place. Today coming home it was about 70 degrees outside and the engine ran right at 180 and the fan never kicked in.
