STBRetired
May 07, 2020Explorer
Fan clutch work-around
The fan clutch failed on my 1999 F53 class A motorhome. It would not engage the "full on" mode for the fan so the MH would overheat when any load placed on engine. Was on my way home for a Dr appointment and could not spend a couple days getting it replaced. Went to Auto Zone and picked up a 16" electric fan, mounted it to the front of the radiator and wired it to run whenever the ignition was on. Worked surprisingly well. Not something I would consider as a permanent fix, but it got me home while keeping the engine temp under 215 degrees. Even when climbing a few longer grades that had me worried.
Just thought I'd share in case someone else ends up in the same predicament.
