live4thedash's avatar
live4thedash
CO alarm tweaking low power and No ceiling lights
Hi,
I have a 2007 Tiffin Allegro Bay
My CO alarm in the bedroom keeps beeping, light pattern indicates low voltage.
In addition in the bedroom the two ceiling lights won't turn on.
What I've done so far.
1. my coach batteries are new and connected so penty of juice there.
2. Also connected to shore power
3. My GFI's are working
4. My generator fuses are set.
5. My circuit breaker looks okay nothing is flipped.
So I'm not sure what I'm missing to be causing this issue.
thank you!
  • Could be the CO2 alarm needs to be replaced they do have a use life usually around 7 years. Check the expiration date on yours, Is it 120 volt or 12volt. does it have a battery back up if so does a new battery stop the beeping. Do you have 12 volt at the light? could be bulbs are bad.
  • Do you know if the CO alarm is powered on the same circuit as the lights?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Check voltage at house batteries, Make sure the disconnect is in the CONNECTED (Use/ON) position, if you are plugged into shore power check converter and its breaker for proper operation, DO NOT TRUST eyes on circuit breakers, TOUCH them.
    Then you need to start following the light..
    With the RV not plugged in
    Get a test lamp, this is a tool that looks like an ice pick with a plastic See thourgh handle, a light bulb in the handle and a wire with clip coming out of hte handle
    Start at the batteries, Clip to one post (Negative?) tip to other LIGHT good
    move tip to chassis LIGHT =bad ground
    Move clip to chassis, touch battery positive to make sure you have a good ground and a bright light.. now move out along the positive wire. If you engounter any device, check both of the terminals (if it has 4 just the big ones)
    As you move the clip, check back the last good test point to make sure you have a good ground still.
    Problem exists between BRIGHT and Dark test points.
  • okay, update
    Validated batteries are in series. reconnected put a meter to it and it reads 12V.
    I don't have an inverters
    The CO2 alarm still beeps low voltage and two ceiling lights still don't come on. However all of the other lights work in the bedroom including the closet. thoughts??
  • I think it may be the I had them in parallel. as far as output how do I know which one goes to ground and which one goes to positive (12 volts output).
  • You say coach batteries are new. Any chance you got 6 vole batteries connected in parallel? You would really have low voltage (6V) that way.
