rfsod48's avatar
rfsod48
Coach batteries
I need to replace my coach batteries. 95% of the time we are hooked up to shore power. Currently we have 6 6v batteries which are wet cell. With our limited use would it be best to stick with this type of battery or would it be better to go to AGM type?
  • hershey wrote:
    ,,, 2 - 6 volt batteries would be more than adequate for your needs ,,,
    I was thinking the same. 95% of my nights are connected to shore power and two 6 VDC batteries are more than adequate. I'm wondering if the count includes engine start batteries also which would be more in keeping with a typical configuration. 2 chassis, 4 coach. I would stick with wet cell. AGM are very good batteries but unless your travels have you off the grid, a lot, the added cost would be better used for fuel and CG fees.
  • From what you described, 2 - 6 volt batteries would be more than adequate for your needs. Unless by chance you have an all electric refrigerator??? Having said that, 4 - 6 volt batteries would be more than adequate...that is what the majority of MH's have.
  • When going down the road, your batteries are being charged continuously by your engine alternator.
    Decent AGM's will cost about $200 each and are probably not needed unless you like the zero maintenance aspect. If you still want to use AGM's, as suggested, go with four instead of six batteries.
  • Normally we only use battery power in rest stops or going down the road. So you feel it would be feasible to go to 4 6v instead of 6.
  • The AGM vs wet cell has less to do with capacity than with the trade-off of no maintenance vs cost.
    And, if you don't dry camp, there is no need for that large a battery bank-- irrespective of whether you go with wet cell or AGM.
    Said another way, 4 golf cart batteries (around 440 amp-hrs @ 12 VDC)would be ample for the way you use your coach. Save the money and weight.
  • I forgot to include that we have a 2005 Fleetwood Bounder with Catipillar C7.
