Ivylog wrote:
If you convert the 200 minutes to hours and X 25 you get 83 AH which is about right for a cranking battery. A deep cycle battery that weighs that much would have around 125 AH.
I replaced my 10 year old Interstate 31s last summer as Interstate made me an offer I could not refuse at the FMCA rally in OR... I got to keep them. I put them in a 24V machine I own and they are still going strong. I did find the caps under the hard plastic top of these "maintenance free" and would add a small amount of water every two years. Taking the caps off and checking the Specific Gravity of each cell will tell you a lot about them.
Was Google searching and found this reserve capacity x .60 = ah
so 200 x .60 = 120 ah This was for deep cycle batteries .
I think this must be right . that's some serious amp hours with my 2 batteries total 240 amp hours . thanks for the info . used these batteries last weekend and had tv going bunch of lights fans xm radio going all night etc .
Batteries said still full charge after 10 hours . I was amazed .
next time i use them again i will check with voltage meter .
Itasca55
