- DpsebringExplorerReplaced the relay transfer switch and all working great...Thanks
- DpsebringExplorerSounds like what I have to do. Will be back if it didn't fix the problem. Thanks for all the help.
Dan - alstondExplorerExperience same problem on my 2005 Cross Country. I replaced the relay transfer switch, problem solve. Switch was located in the rear passenger side compartment.
- DpsebringExplorerOk guys, I found the relay and one of the two 5 amp fuses was bad. I replaced fuse and it blew again. I tried it again with same result. I am thinking it is a bad transfer relay which I can get for about 50 bucks. Any thoughts out there?
I guess I am lucky it failed with the power in the on position. For the time being I disconnected the neg. on the coach batteries.
Thank you,
Dan - The 5 amp fuses are mounted ON the disconnect relay. Doug
http://www.rvtechlibrary.com/electrical/battery_disconnect.pdf
https://www.ebay.com/i/162546733765?chn=ps&dispItem=1 - DpsebringExplorerThanks for the reply. Any idea where the relay is located? How about the 5 amp fuse? I checked the fuse and relay box in front left panel on outside and it's not labeled there.
Dan - If you do not hear the click, check the 2- 5 amp fuses on the disconnect relay. IF they are GOOD, odds are the relay is bad. You should be able to hear it click in both USE and STORE. Even if it is in USE mode, it will click if good. Doug
- wa8yxmExplorer IIIAssuming for the moment an INTELLETEC Battery Control System.'IN the BCC there are several fuses. Some are 5 amp ONE OF THOSE controls the switch.
Remove all 5 amp fuses
Cycle USE/STORE switch like 100 times, both ways
Replace switch
If it works,, GOOD, if not your FREE is hereby cheerfully refunded. - TrackrigExplorer IIYou're better off taking off the negative battery cable. If you're using the OEM cut-off switch, it most likely doesn't kill all of the power and your batteries will eventually go dead.
Bill
38,763 PostsLatest Activity: Dec 05, 2025
