llamsm wrote:
1994 pace arrow motor home. Hello all. been dry camping since Thursday, had the generator running the whole time without any issues. went to get ready to leave started the RV let it run a bit raised the jacks. went to put the rv in drive and it acted like it had no power and kinda sputtered and wanted to die put back in park hesitated a little but rev up and idled fine tried it again same think sputtered and would not hardle move and wanted to die like shut off. back to drive seemed to idle fine till I tried to put it back in drive. almost like no fuel. any one have any ideas on what could be the issue before I have it towed. thanks for your time on this matter. Mike
If you have a fuel filter on the inside frame rail, passenger side about half way back, remove the outlet side and then crank the engine to see what comes out. Good place to install a pressure gauge as well.
If your fuel pump in in the tank and needs replaced, try going thru the floor above, instead of dropping the tank and then finish it off with a marine type access plate.
