I guess the obvious question is why. It would be a safety issue to remove the automatic step. Manual steps work on trailers because you have to pull them out to get in and then close them when driving.
On a motor home you would have to jump out and then open steps. Then you would either have to close them and crawl in or lay on the floor and pull them in. Your idea doesn't make sense and could be a hip or leg breaker. Maybe even a face plant!
If you're having issues, rebuild and adjust properly or replace with new. When my Monaco was about 8 years old, I bought all new bushings for the pivot points and replaced them. I adjusted and lubed the rest of the mechanism and they worked like new.
