crasster
Mar 10, 2017Explorer II
If you have access to a router, you can drill a hole and use the router to make any shaped hole you want so long as the bit is shallow enough. Also do climb under the coach and check things out first if you have not already.
38,782 PostsLatest Activity: Sep 10, 2026
