lordnorth
Mar 30, 2018Explorer
Freshwater Tank Replacement - Coachman Mirada (Solved)
I believe I have a leak in my system upstream of my water pump. This means either the line going to the pump, the connections, or the tank itself.
I am trying to find out 'worst-case-scenario' information.
If I DO need to replace the fresh tank... How do I go about doing this?
It is a 2011 Coachman Mirada 35BH.. I can *see* the tank through the very top of a compartment on the passenger side, but I have no idea how I would get in there to remove the connections, let along detach and remove the tank.
Can anyone help? I doubt you go in from the top... though that would certainly be the easiest. Can't see how you would go in from the sides. Going in from the bottom seems like it would involve cutting.
Is there something easy I'm missing?
Thanks for the help!!!!!
-Chris
-Chris
