After a fridge fire, the insurance company contracted ServPro to clean the coach. They did a great job cleaning, but putting things back is another matter. They removed the switch box, the satellite...
You have all the equipment needed to test right there. You have signal sources: the antenna, VCR, DVD, etc., and your destination monitors: all the TV's. Start touching pieces of coax together (or use an F barrel) and it should go fairly fast. The only trick is finding the antenna if the switch box is also the power source, but that HD tester won't tell you that either.
