ronfisherman
Dec 14, 2013Moderator
I did a quick Google search. Fault code 14 is a over frequency fault. This is caused by your generator running at a higher frequency than 60 Hz.
I have a Kill A Watt meter that I plug into a 120 volt receptacle. One of it's readings is frequency. You will probably see a higher than 60 Hz reading when generator has no load on it. Usually requires adjustment of the governor speed to get proper Hz.
38,782 PostsLatest Activity: Sep 20, 2026
