jauguston
Dec 14, 2013Explorer
Good advice on overcycling. The cycles are controlled by engine rpm. A Kill-A-Watt meter is a good investment and will tell you what the cycles are. With no load they should be about 62 cycles and at full load should drop to about 58 cycles. If they are out of spec try lubing all the throttle/governor linkage. If that doesn't fix it the governor may need to be adjusted. That is done on the linkage.
38,782 PostsLatest Activity: Sep 20, 2026
