jgraham429's avatar
jgraham429
completely dead
I have a 2001 Damon Challenger which I moved in order to cut the grass under it. When I went to move it back it is completely dead. Nothing connected with the dash is working. My house batteries appear to be okay, but when I tried to use the emergency start it did not work either.. All I am getting is absolute dead silence when I turn the key on. Even my electric step will not retract. Damon literature mentions a battery control center, but I have no idea where it is. Any ideas anyone?
  • Thanks SacsTC. Checked the connect/disconnect everything is fine there. As for the BCC, I found what I think is the BCC, but basically it is just fuses without a reset button which the manual says it should have.
  • Did you by chance hit the connect/disconnect switch by the door as you went out??
    BCC should be under the front hood on the drivers side.
