donfrump
Dec 29, 2015Explorer
bsinmich wrote:
If you look at Class As you will find that Newmar lists the R value of insulation in their brochures. A couple others may list their insulation R values. The entry level MHs will be more susceptible to your problem. Newmar also has the quietest AC system I have ever had in my 46 years of RVing.
no more quieter than my ducted tiffin air system.my unit has 9 ceiling intakes and 9 outlets my friend has a 2014 Dutch Star and his noise level is same as mine
regarding Rv moisture its a different deal when talking a high to extreme humidity in hot south florida verses a -10 degree is south Dakoda and the warmer( in winter) u keep the inside verses the outside the more moisture u will get and LPG verses other methods makes a big difference also
