- azdryheatExplorerFirst, stay away from any tire made in China, you're just asking for trouble. If you can install a truck tire then do that and you won't have any tire issues.
- BurbManExplorer III
MFL wrote:
BurbMan...not saying your thought of replacement is wrong. My disagreeing, is only a difference of opinion. :)
Hey Jerry, my Dad used to tell me that I was always entitled to my opinion, no matter how wrong it may be...LOL
When it comes to vehicles, I agree with you 100%, I buy the best tire I can find. Tires are not the place to skimp when it comes to bad weather and heavy traffic.
I actually converted to LT tires on the trailer back in 2012. I went from 15" to 16" rims and installed a Lippert Correct Track alignment kit to give me the 2 1/2" of lift I needed.
I used the TowMax PowerKing or whatever they're called for years until one blew out, that's when I decided to make the change to LTs. I decided I was done once and for all with cheap maypop trailer tires.
What I found out while installing the Correct Track kit was that the shackle bushings were shot, one of the shackle plates was almost worn through, and the "smoking gun": The Trail Air equalizer was rusted and frozen in position. Unable to articulate, the equalizer wasn't able to balance the load between the curb side tires, resulting in the tire that blew being significantly overloaded.
So what I thought was a tire problem was really a suspension problem.
Fast forward 4 years and my top-quality LT tires still had 95% of their tread left but the sidewalls were badly checking so I had to replace them anyway.... - JIMNLINExplorer III
colliehauler wrote:
The Carlisle HD as long as their not the standard worthless Carlisle tires. As others have suggested I would go with a larger size 13" tire if you have room with the highest weight rating. It sucks to have a flat on the way to a camping trip.
Good point.
Carlisle has 5 different trailer tires in their catalog so it makes a huge difference is which one is selected for a road trailer. At the top will be their;
Radial Trail HD.
Other Carlisle trailer tires are;
Ultra Sport LH
Sport Trail RH
USA Trail
CSL 16 all steel...16" load G .
A few ST brands are well suited for a road trailer. Other ST brands work fine for utility trailers/other trailers that make trips around town a few times a year. - MFLNomad IIBurbMan...not saying your thought of replacement is wrong. My disagreeing, is only a difference of opinion. :)
I notice that another opinion was posted at 7:10 last evening. The count went up, but no post?? Can we guess who that will be? Lol, we will likely see, later today, maybe tomorrow, just above my post.
Jerry - LwiddisNavigatorMitch, I too have used eTrailer tires and am pleased with price, service, endurance etc.
- MFLNomad II
BurbMan wrote:
Those brands are about the same. Just be sure to get the same LOAD rating or heavier than what you have. If you didn't have any issues before with blowouts you won't now either.
Trailer tires age out before they wear out even if you use the trailer a lot. Better to go with the cheap brand and replace them in 4 years than spend for a premium brand and try to get 7 years out of them.
I am going to disagree with this logic. The newer premium ST tires are better built, higher speed rated, and IMO, worth the price difference. I have 8 years on my Providers that came OEM. Although not worn out, still look great, plan to replace this Spring. E-trailer sells them, and gives a good review, why they are top rated.
I would still get the premium tires, even if I chose to replace every 4 yrs.
Jerry - colliehaulerExplorer IIIThe Carlisle HD as long as their not the standard worthless Carlisle tires. As others have suggested I would go with a larger size 13" tire if you have room with the highest weight rating. It sucks to have a flat on the way to a camping trip.
- BurbManExplorer IIIThose brands are about the same. Just be sure to get the same LOAD rating or heavier than what you have. If you didn't have any issues before with blowouts you won't now either.
Trailer tires age out before they wear out even if you use the trailer a lot. Better to go with the cheap brand and replace them in 4 years than spend for a premium brand and try to get 7 years out of them. - Sandia_ManExplorer IIOf the 2 choices I would go with the Carlisle HD, Carlisle ST tires have improved over time. Goodyear and Maxxis ST tires are better choices, keep in mind that ST tires need to be aired up to max psi for best results. Secondly, they are really only good for up to 5 years, that is when we always got a new set, never had any blowouts or even a flat with our ST tires, and yes we went above the 65mph threshold as needed. Main failure points for any ST tire is improper inflation and overloading, common occurrence since manufacturers barely put enough axle and tire under most of their rigs to begin with.
- APTExplorerI'm happy with Carlisle HD. I have them on my TT for 5 years now and one utility trailer for 2.
44,070 PostsLatest Activity: Sep 18, 2026
