wolfe10 wrote:
Correct.
Axles have their weight limits.
But, the GVWR may be based on other factors such as brakes, transmission, etc.
Both numbers are important.
Yes,
The axles have their limits but, shouldn't the GAWR of the rear and GAWR of the front add up to the GVWR? If I'm not mistaken, they do on our coach. Our coach is an '04 Itasca Horizon 36GD with the CAT C-7 330HP. The rear axle is rated at 17,500 lbs. and the front is rated at 10,410 lbs. The GVWR on my coach is, 27,910 lbs. and says so on the drivers tag on the wall.
Scott
