two_travelers's avatar
May 04, 2018
Confusion on weigth
We have a 2015 Winnebago Vista. The sticker on the wall near the driver shows a GVW of 16,000#. The GAWR shows 6,500# for front and 11,000# for the rear. These add up to more than 16,000#. Had the coach weighed and we have room to spare. Do I go by the GAWR in figuring my spare capacity??
Thanks!
  • Correct.
    Axles have their weight limits.
    But, the GVWR may be based on other factors such as brakes, transmission, etc.
    Both numbers are important.
  • One is the maximum you can put on that axle. If you reach maximum on one axle, you should cut the weight on the the axle so you do not go over your gross vehicle weight.
  • The sum of the parts is always larger than the overall max.
