rjgraph
Jun 25, 2014Explorer
enblethen wrote:
There is a fuse link down by the starter. It connects onto the battery terminal of the starter and feeds the fuse block under the dash. Fuse block under the dash is to the right of the steering column. Awkward to get to unless you have a driver's door. There is a main fuse on the fuse block. Should be marked "IGN" on some.
Great. I will have to try that. Any idea as to what it looks like? I do have a drivers door and I have checked all the fuses. I will see if I can find the IGN fuse. Any idea as to what amp it would be?
Thanks!
38,769 PostsLatest Activity: Jul 09, 2020
