rjgraph
Jul 02, 2014Explorer
enblethen wrote:
The relays in lower photo are the battery disconnects.
You could try to cycle them, off then back on. I doubt that is the problem.
In the box there should be fuses. Double check them.
Thanks for the repair advice! It was the fusible link at the starter. Changed it out and started right up. Advice for all check the terminals on your new batteries. They swap them around. Its a******shoot on the same side as prior.
Here is the problem.
Final fix
38,776 PostsLatest Activity: May 14, 2026
