PghBob
Apr 04, 2014Explorer
Hi Josh44:
You noted that you "don't know much about motorhomes". I suggest that you pick up a copy of a Buyers Guide to Motorhomes that lists many RV manufacturers, specific units, floor plans and other specs. It will provide you with information and help you become familiar with RV specific terms and lingo. Yes, the prices will be list and for new units, but it may help you see the cost difference between high-end and low-end RVs. If you have the time, go to an RV show so you can see various floor plans, build quality, and options that you might be interested in buying. You can also purchase at the shows and you might be able to get a new RV for what you might be willing to pay for used.
Most important is to check out the unit's OCCC (Occupant and Cargo Carrying Capacity). This is the max. amount of weight a particular chassis can carry and includes all passengers and all stuff no matter the space or room available. OCCC is reduced with options, particularly slide-outs and leveling systems. Also, keep in mind that tires on RVs should be replaced at 6-7 years or when cracks develop in the sidewalls no matter the tread wear. Finally, water leaks into the coach are not good, and are expensive to repair and take time away from enjoying the RV. Most folks on this board would walk away from a leaky RV.
Best wishes for success. Bob
38,782 PostsLatest Activity: Sep 10, 2026
