coljhossExplorerApr 29, 2014converter bad1995 bounder class a.the only thing that works is 12 volt lights.plugged into shore power.the converter is behind fuse box.i believe it is bad. can i bypass converter by running hot wire that goes int...Show More
sch911ExplorerApr 30, 2014If the 12V lights work only when plugged into shore power your converter is working. To me it sounds like you have a dead battery.
