mowermech's avatar
mowermech
Explorer II
Jul 13, 2014
Converter location: UPDATE!
The coach: 2002 Fleetwood Southwind 32V on a Ford F53 V10 chassis.
The converter does not seem to be charging the batteries, regardless of power source.
But, I can't find the fool thing! All I can find is the Power Distribution Center (PDC-3009). That, of course, is nothing but a breaker/fuse box.
Does anybody know where they hid the converter?
UPDATE: FOUND IT!
There is a drawer underneath the frig, with 2 small grilles in the cabinet under the drawer. The PD 9155 converter is hidden under there. I found that it has one 30 amp and one 20 amp DC fuses. They are supposed to be both 30 amp. It does have power at the cord, and it is drawing power. I need to take my Fluke out and verify the output, and if there isn't any, replace the fuses even though they look good. If that doesn't fix the problem, it may be time for a new converter.
  • You may find that the converter is behind the distribution panel on my winnie with the F53 thats where it is located. Make sure you kill all power before pulling it. When mine went I replaced it with the upgraded model with more amps. Good luck
  • I don't have the same mh that you have, however, my converter is behind the drawers which are between the under sink cabinet and the power fuse center. If you have any drawers in that area remove them and look around with a flashlight.
    Hope this helps.
