- 2oldmanExplorer IIIf it's humming.
- John_WayneExplorer IIIf it's up by the TV I don't think it's the converter..I'm talking about a converter that takes 120 volts AC and makes 12volt DC. Is this what your talking about??
- Check the battery voltage. If close to 13.6 or rising the converter is on. If voltage is 12.7 or less and dropping the converter is off or not functioning.
- CT_WANDERERExplorer
J-Rooster wrote:
I own a Winnebago Adventurer and my converter is mounted next to the overhead TV, above the DVD player. There's a green light on in the unit when the converter is on.
I could be wrong as I don't have a Winnebago but aren't you talking about an inverter. I thought my friend had an Adventurer and he said that his inverter was up by the TV. It would not be the first time I was wrong. Gary - wny_pat1ExplorerThe converter/charger? If your plugged into shore power, it should be on. But depending on the coach, you could have some type of power management system that has tripped.
But the TV converter??? - J-RoosterExplorerI own a Winnebago Adventurer and my converter is mounted next to the overhead TV, above the DVD player. There's a green light on in the unit when the converter is on.
38,766 PostsLatest Activity: Jan 10, 2026
