brinson's avatar
brinson
Converting from Dometic to residential refrigerator
I am looking for recommendations of possibly switching from a Dometic to a residential refrigerator. The cooling unit has failed in the Dometic and now seems to be a good time. The Dometic is a RM 1350 and wondering if anyone has a particular unit that anyone has replaced it with. I typically always stay somewhere with shore power.
  • BurbMan wrote:
    If you're up for a road trip, we found these guys at National RV Refrigeration in Elkhart, IN. If you make an appointment, they will repair your fridge in your RV while you wait.
    Just an FYI, Leon Hershberger owns National Refrigeration and he is in Shipshewana. His business is now at his home just north of town and he can accommodate RV's.
    Dale
  • You're right it was Shipshewana. We were there in June to pick up a scratch/dent for our truck camper and there were 2 buses and a large 5er parked out front getting serviced. They open at 7:30 am! We went through Elkhart to pick up the filon next then to Bontrager's Surplus.
  • brinson wrote:
    I see what you guys are saying, doesn't look like you can replace the whole unit unless the slide is removed. Probably not what I would want to do.
    Did you check to see if there is clearance through the windshield? This is a much better option than slide removal.
  • As best I can tell, it will not go through any opening including the windshield. I did talk to folks at Rvcool.com in Arkansas near me and they told me to remove the cooling unit and turn it upside down for 24 hours since my unit has no visible leak. They claimed they can become vapor locked and sometimes this will correct the problem.
    I turned the entire refrigerator upside down for 24 hrs. and uprighted the unit today. I let it rest for 2 hrs and then wired it back up in the middle of the floor before reinstalling. The unit is cooling down and seems to be working well so far. Apparently, it had a vapor lock as Rvcool.com suspected.
