03 RoadKing wrote:
Ok doing my yearly maintenance. Everything I hear about checking the additive is to put the test strip into the coolant in the radiator and not the recovery tank. Problem with that is with a side radiator there isn't a cap to open on the radiator. What do you folks do to get a good reading.
never heard that one? If one knows that no new antifreeze or water has been added and the vehicle has been run sufficiently as to know the coolant has circulated properly then test strip in the overflow /recovery tank is good to go
