bodomalo
Dec 02, 2014Explorer
JFreitas wrote:
Technical Report No. 2
* If reservoir level does NOT CHANGE between hot and cold, radiator level is low.
Recommendations
* Radiator level should be checked (by removing cap) at every oil change (Caution: Open only when cold. Contents under pressure.)
* Reservoir level should be checked for HOT and COLD level at every fueling. (Cold level should be checked before starting a day's trip before start up.)
* Radiator level (as well as all fluid levels) should be checked before and after storage of one month or more.
So radiator level in the system might be low and I should open the pressure cap and fill in some more... thats what I understand.
38,782 PostsLatest Activity: Sep 10, 2026
