- vacuumbedExplorer*Update*
I found the drain plug on the side radiator. It is on the tank closest to the front of the RV.
I bought Fleetguard coolant. They sold me the blue stuff and said it is okay to mix it with my old green coolant. - tropical36Explorer II
vacuumbed wrote:
You may have to pull a hose for draining and I only use CAT coolant with mine. Cummins surely has one or compatible, also.
Hello everyone,
Has anyone attempted this at home? I changed my coolant filter once, but I have never done the coolant. I am not able to tell what the capacity is or where the drain plug is.
This is a 96 Monaco Executive diesel pusher with the Cummins M11.
Thanks in advance. - wolfe10ExplorerNot a difficult job. Yes, you do need to determine total system capacity and make sure you have a diesel-compatible coolant.
If you want the step by step instructions, let us know.
38,778 PostsLatest Activity: Jun 10, 2026
