Kidoo
Dec 11, 2014Explorer
Coolant reservoir leak
Just a note if your coolant reservoir leaks. I spent the hole day today trying to fix a leak from the coolant reservoir on my Cayman 2003. I cut the hose so I could push it in a little more, then the hose would just not go back in, it has a reinforced wire winding that is just smaller than the lip on the reservoir. So I replaced the hose with a new one, re-installed, still leaking. So I replaced the clamp, I also used a different type of clamp, exchange it again at the store, rethighten everything many times with the original clamp, no luck.
After 4 or 5 trials, emptying the said reservoir every time and refilling, I was getting very frustated. I found out that you have to place the clamp exactly at the right place, not too far in, not too close to the reservoir bottom lip. Finaly, at the end of the day, in the dark, I found the spot and it stoped leaking, what a frustating day.
