Have any of you refinished your Corian counter tops? How did they turn out? The process looks easy enough, just makes me nervous taking sandpaper to them. Thanks, Merry Christmas and safe travels
start out slow and stay slow, get you a spray bottle of clean water and many rags. Depending on how bad, you can start out at 250 plus, if not bad then go higher to start and slowly get the finish you want. Remember the higher number you go the sandpaper the smoother the finish and the easier to scratch again. I do ours every couple years.
I start out with 400 and end up in the thousands grit. My kit goes up to 15000 grit. See if I can find the link I use.
