obiwancanoli's avatar
obiwancanoli
Cost to install apparatus for Flat-towing
While I've had and used a Tow Dolly for a couple years, I've always found it inconvenient, requiring me to have storage when not in use. As a result, been considering replacing this with a towing apparatus for my Class A, and called Camping World to research, and get an estimate...
WHOA!
At $5,400+, it was quite a bit more than I anticipated... but is it accurate? Looking for input, experience, and anything else that will help me decide if this is an option I should consider...
At this price, I think I'd continue with the dolly...
Your thoughts?
Thanks, MIchael
  • Are you buying everything new? I bought a used ReadyBrute that looked brand new for $250. Had Night Shift Auto go through it at a rally and they said it'd hardly been used. Bought the baseplate directly from BlueOx for a little over $300. Wiring harness was around $200. So for less than $1k I'm ready to roll. I've been using it for 11 years now and it's still working well. So, I'm into it for less than $100/yr.....Dennis
  • You chose one of the most expensive places you could to buy and install the needed parts. Check amazon or other rv parts suppliers for parts and get a local body shop to install.
    I bought everything I needed and installed myself for less than $1K.
  • We need a little more info. I towed a Chevrolet HHR, that was rated for towing 4 down, and all I had to do was install a tow bracket on the vehicle, set up the tail lights, and buy a tow bar to use. I believe my total cost was around $1200.
    If your vehicle is not rated for towing 4 down, there may be some additional costs for a disconnect for your driveshaft in addition to the cost for the tow bracket, lights, and tow bar.
