- mike_brezExplorerI know I only have little 19.5 wheels but I just did mine last month.the fronts only. Start to finish about two hours. The biggest pita is removing and reinstalling the lug nuts by hand.
- JetAonlyExplorer
nina_70 wrote:
Has anybody paid to get their wheel bearings re-packed on a Class A? Prices?
We got a quote for $450 for all our bearings (we're 40-feet 2008 HR Endeavor RR8R Chassis, 2 tires up-front, 4 tires in the back), or $596 to change to oil-fill.
Is this in the ball-park?
I just had this done on our RR8 chassis. $380 for labor and $95 parts. First time done, as far as I know. No problems with spindles or any thing else, so I'll do it next in 2026. That is the benefit of greased hubs.
YMMV - C_DuckExplorerNina...Go to the Monacoers Group on Yahoo, there was a recent thread on this very topic. This a good site for Monaco owners with some VERY knowledgeable people.
- Sully2Explorer
MCIbus wrote:
If you go with oil bath you will need to drive every 30 days or so. The oil sits on the bottom part of the bearings and the tops of the bearings dry out and could passably rust over the winter.
HORSE MANURE!! - wny_pat1Explorer
deandec wrote:
I had our first repack done at 70,000 miles and 14 years on front wheels only. I think it was about $300.
Shop said everything was fine.
Now at 94,000 miles with no known problems.
I do not know what the benefit of oil hub bearing lube is on these rigs.
Benefit - all the big rigs have oil bath hubs. Never need to repack the bearings with grease. That is the benefit. The bearings are constantly getting oil. - deandecExplorerI had our first repack done at 70,000 miles and 14 years on front wheels only. I think it was about $300.
I do not know what the benefit of oil hub bearing lube is on these rigs. - SoCal_KevinExplorerNina 70, does your Owner's Manual list a maintenance schedule for your bearings? At the least, that would answer what kind of bearings you have and if they are recommended to be serviced.
- bluwtr49Explorer II
Never heard that before. Ours are oil bath and typically the oil leaves a film that prevents any problems. Beside, in only a couple of revolutions it's all lubed again. - NomadacExplorer
I doubt that as mine sits for 3-4 months over the winter and I have never had any problem. I recommend reading the maintenance recommendations for the front axle to be sure what is needed. Those that winter in southern states do not drive their MH for the 4-6 months they are parked. - MCIbusExplorerIf you go with oil bath you will need to drive every 30 days or so. The oil sits on the bottom part of the bearings and the tops of the bearings dry out and could passably rust over the winter.
38,707 PostsLatest Activity: Mar 03, 2025
