Sully2
Jul 07, 2014Explorer
mike brez wrote:
Ok. The Magna 1999 has one slide. He said the temp gauge on dash reads hot but the digital info center reads normal. Also the tach needs a sensor but he uses the same digital info center to monitor it. Had it serviced at the Cat place and said there are no codes or problems. Has some peeling clear coat on the roof radius. The engine a/c just got a new compressor but needs freon. Back up camera not working but has a new one in box to install.
2004 Inspire has three slides says outside looks like new and inside only thing wrong is three cracked tiles and has three windows that are foggy. Has jacks and 10 gal hot water heater.
Both have newer tires and batteries.
Take this info in hand and call Country Coach and talk to Tech Support. Explain it all to them and ask where the nearest high rated CC repair place is. They can tell you and you can get in touch with that place
