23hotrodr
Jun 24, 2018Explorer
Floridarosebud- I think the Safe-T-steer you reference and the Bilstein stabilizer are not the same type devices at all. The Bilstein is simply a dampner that helps you control sudden movements. The Safe-T-Steer is most likely a self centering dampner that tries to help you hold the steering in the center "neutral" position along with dampning. It sounds like the Safe-T-Steer is not centered and needs to be adjusted by getting it "centered again on your steering components. Just make very small adjustments until it is centered again. The self centering is much better than the simple dampner.
I have the Safe-T-Plus and it does take a few trial and error adjustments of the attaching bracket on the tie rod to get it centered, but once adjusted, makes a big difference. Good luck-- Mickey
