Mr_Mark1
Dec 08, 2014Explorer
larry cad wrote:
Air pressure should hold up longer than that. Take a spray bottle with soap suds in it and lay under your coach and spray all the air fittings while you have it pressured up and look for leaks.
And, if you are under the coach, make sure that you have the suspension supported so that you are not crushed if it drops.
MM.
