Brandon327's avatar
Brandon327
Crack in fiberglass next to slide
[img][/img]
I am looking at buying a class A motorhome and it has a crack in the fiberglass next to the corner of a slide. Is that a cause for concern ? Is it a fairly common problem?
  • Thanks for the reply’s. I am going to avoid it like the cornavirus. I don’t need to buy problems.
  • Could be. I can not see your image. fiber glass can be high dollar if you can not fix your self. Also is it stress /damage from being hit.
    If stress you going to have hidden repairs to correct it.
  • Yes. Stress cracks. A friend had that problem, had it fixed, but it returned. I would avoid that coach.
