whporwil's avatar
whporwil
cracked counter top
I just did a search for cracked counter tops and there is nothing.
I have owned two rv units. The first was a new 2008 Jayco Designer and that solid surface counter cracked from the back corner of the stove top to the back wall. Our second is a used 2006 Winnebago Tour and this is cracked from the front of the sink out. We discovered this about a week after we bought the rv. So I'm two for two on counters. Am I the only one and has anyone successfully repaired there counter.
Thanks
  • Mine cracked too, the Corian is very easy to find someone to fix it. I contend that driving it cold in very low temps did me in.
  • years back I was looking at some Newmars that had a "corian" counter top. some of their cheaper ones had a very thin layer of "corian" and one on the lot had already begun cracking from a sink corner to the wall. they also had a better thicker almost solid counter top in the upscale units. so be sure what you are buying.
    but no I don't think they can be repaired. I have seen ads for firms' that would recoat the counter tops with something and that would possibly work.
    bumpy
