path1
Jan 15, 2018Explorer
lordnorth wrote:path1 wrote:
As last resort if you can't find replacement and have to make your own...look up "frp paneling". Cut with very fine, most teeth in saw blade as you can get.
Yes! This is exactly what I need. I was thinking that the panel and the insulation were one piece... but now I'm wondering if the panel is just laid over top of the insulation? That is even better than I had hoped if that is the case!
Thanks!
Might be glued down or actually held in place by alum trim that holds door together. Not much to them but doors cost $$$. When cutting I duct tape wet dry vac near blade exhaust. Stuff flys everywhere.
38,782 PostsLatest Activity: Sep 10, 2026
