Tom_Barb's avatar
Tom_Barb
cracked exhaust manifold
we discovered today that we have a cracked exhaust manifold on our cummins 8.3 ISC. local diesel repair shop says this is pretty common in motor homes.
anyone concur ?
looks to be about $1000. in parts to replace. (estimate from Cummins northwest)
we noticed a loss of boost pressure and a higher than normal EGTs the last hour of our return trip yesterday. Today Started the inspections to see why, and found the crack is totally around the casting between #2 and #3 cylinder. fortunately nothing burned in the area.
  • I had Motor Truck in Bellingham replace mine a few years ago. IIRC, the parts were under $500 and labor ran about the same. No way should parts cost $1000
  • johnhicks wrote:
    Assume $2500. The tech will break a bolt or two. It's common.
    The Tech is me.. I do all my own maintenance, always have.
    This is nothing more than replacing a part, oh but a big one.
    If I had to remove the engine, I'd take it to Motor Trucks in Mt. Vernon, they have power lifts.
  • wolfe10 wrote:
    Between 2 and 3 or 3 and 4 (in the "larger part") not the short front part??
    Read the post.
  • Between 2 and 3 or 3 and 4 (in the "larger part") not the short front part??
  • sch911 wrote:
    Yes, it's a very common failure mode. How many miles on it?
    a bit under 50k
    Cause ?
  • Yes, it's a very common failure mode. How many miles on it?
