Mnwild
12 years agoExplorer
Cracked 454 exhaust manifolds
I have a 98 P32 with 72000 miles and do all my own maintenance. While servicing the brakes on drivers front wheel I could clearly see the manifold was cracked but does not appear to be leaking. I understand this is a common problem with these engines. I would like to avoid changing this if I don't have to do to the fact that the mounting studs commonly brake off which requires drilling and tapping and possible head removal. Since it is not leaking what are my chances that it wont get worse on our way south in January. Thanks in advance for your advice. Ken
