Cat C7 engine capacity listed at 19 qts ,if I put 2 qts (prefill oil filter) can I then put 19 qts in the crankcase I instead of the 17 that I've been doing ?
17 in my C-7 shallow pan makes the dipstick read normal. I find that if I check the oil after a day or two, it reads high unless I wipe the dipstick before getting a reading. This is including the filter change.
