My 1997 Winnebago Chieftain has one living room slide. Even when I have the 2 floor latches locked the slide will move out an inch or two. Thoughts on fixing this? Thank you in advance.
1997 should be HWH hydraulic. Before replacing the Extend solenoid, open BOTH the Extend and Retract T handles on each solenoid and run the pump motor in or out for about 10 seconds. With BOTH open the room will not move much, but this will dislodge any possible debris stuck in the needle valves of the solenoids. Then close the T handles. Then retest. If it still creeps out replace the extend solenoid. Doug
