flavionics's avatar
flavionics
Cruise Control Downshifting
I have a 31' Minnie Winnie on a E450 chassis and I question rather or not the Cruise Control can be adjusted somehow as to not down shift when going up the slightest hill. This usually scares the bejesus out of me and I would expect not good for the MPG and transmission. I understand this happens to maintain speed, but I would be willing to sacrifice a couple of miles per hour to keep from what I feel is a somewhat violent manuver.
My previous class A with a Ford F53, seemed a bit more resonable sacrificing MPH before the downshift.
  • My guess is the older MH had better power to weight ratio so it was set to hold in the higher gear on steeper hills. The new one presumably is lugging the engine on less steep hills, so it downshifts.
    There's a reason it wants to downshift. If it does it once in a great while, just let it. If it's doing it every few minutes, turn the cruise control off so you can bleed off a little speed rather than downshifting or manually drop down and run in a lower gear.
    I find if there are any significant hills, it's usually easier to manually run the throttle as I can feather it to bleed off some speed on the uphill and pick up speed on the downhill without a lot of downshifting.
    You don't give the age but does it have the tow/haul mode that a lot of the newer pickups have? They seem to do a better job.
  • I've had this in several trucks. The cruise is trying to maintain speed.
    I ended up shutting off cruise. I can let it lose some speed on the uphill and gain it back on the down hill.
    Sounds like it is doing it's intended job.
    I don't believe there is a way to reprogram the ECM.
  • flavionics wrote:
    ..t the Cruise Control can be adjusted somehow as to not down shift when going up the slightest hill.
    Just to be clear, the cruise doesn't downshift, the transmission does.
    Shift it yourself, before the vehicle is struggling on the hill. I've done this in many trucks.
