First, thank you for a detailed description Something that many don’t do when asking a question.
second you’ll be fine. Think about it like this. No hitch weight. And no wind resistance.
it’ll be fine and not much different than currently. Unless the rig struggles now it won’t struggle with the jeep
Thanks Grit. I was hoping you'd chime in. I appreciate your practical advice.
- Grit_dogJan 03, 2026Trailblazer
Yes. Fwiw, for example, towing our 6klb boat with a tower, would drop 3-4mpg. Same as hauling truck camper on same truck. Towing boat behind the truck camper = almost the same mileage as camper only.
or recently towing an empty 3500lb flatbed trailer, mpg drops about 1-1.5mpg from bobtail.
Frontal area or wind resistance is imo more of a factor than weight at highway speeds. At low speed neither is an issue within reason.
