AJR
Nov 17, 2017Explorer
OP, you are absolutely correct. Class Cs are cheaper to maintain. I had a 2002 class A gasser. Loved the floorplan. But everything under the floorplan cost more to maintain or fix. As an example; When the Allison started to drip oil. I had to go to an Allison certified repair center. For way over $700 they remounted the oil fill tube, changed to the “better” oil and maybe replaced a filter. Any Ford dealer could remount the oil fill tube for a fraction of that cost. I also like two steps to get in & out. Plus I have a driver’s door I can just slide out of for gas stops. Even the cab over I did not want turned out to be a great sun shade and storage area.
All RVs will have water leaks if the exterior seals are not maintained.
