MrWizard
Jun 06, 2017Moderator
leave the ignition off
slide underneath
look at the injector pump
while someone steps on the throttle
is the cable linkage to the input control valve moving ?
IF no cheap fix
IF yes, then the injector pump may have died
or the lift pump died, its a lot cheaper to replace
i had the injector pump replaced this time last year, late may 2016
they cost about $4500 for a rebuild, here in L.A. and that is just the pump, not the labor
there are some on ebay a LOT cheaper, the trouble is Matching it up with what you have
its the same pump body, but different (parts/plungers?) depending on which version of the 5.9 you have
the 190hp 230Hp, or larger
mine is the 230hp
hope it is one of the cheaper fixes
slide underneath
IF no cheap fix
mine is the 230hp
38,782 PostsLatest Activity: Sep 10, 2026
